marton
#1 Posted : Wednesday, February 25, 2015 12:51:39 AM(UTC)
marton
Norway
Hello
Just recently purchased ViaCAD Pro 9 and have issues with IGES import.
I am running it on Mac with latest OS and updates.
This is happening with several IGES file I have. The files contain Hull design and does not contain so many curves and surfaces.
ViaCAD imports the IGES file, but it ends up with just circles. How to troubleshoot this?
I can not upload IGES file to forum, because of the IGES files contain business protected hull - lines. But I will try to make a dummy file and upload
If I import the IGES file in Rhinoceros WIP version for Mac, the file imports without issues. If I then save the import as a Rhino file, it imports just fine in ViaCAD as Rhino file.
I have tries all 3 options on IGES import. No luck, same result.
/MartOn
/MartOn
(Mac OSX 10.10.x, ViaCAD Pro 9.0.0, Ultimaker 2 3D Printer)
#2 Posted : Wednesday, February 25, 2015 2:00:10 AM(UTC)
Would it be possible to zip and send me the file to look at in the debugger?
timDOTolsonATevo-soft.net
marton
#3 Posted : Wednesday, February 25, 2015 1:25:46 PM(UTC)
marton
Norway
Just tested IGES import with latest build 1144. Issue is still there.
I am preparing to send a file as PM for debugging of IGES file.
/MartOn
/MartOn
#4 Posted : Wednesday, February 25, 2015 2:09:06 PM(UTC)
FYI, a detailed log for IGES & STEP import/exports can be found in:
/Users/<username>/Library/Application Support/com.encore.viacadprov9/iges_w.log
/Users/<username>/Library/Application Support/com.encore.viacadprov9/step_w.log
marton
#5 Posted : Wednesday, February 25, 2015 4:02:27 PM(UTC)
marton
Norway
I sent you an email, not sure if you received it. I will send iges file when you confirm.
The log on import does not give any errors.
https://dl.dropboxuserco....com/u/272947/iges_r.log
/MartOn
/MartOn
