marton
#1 Posted : Wednesday, February 25, 2015 1:04:03 AM(UTC)
marton
Norway
Hello
Just recently purchased ViaCAD Pro 9 and have issues with PNG import and scale
I am running it on Mac with latest OS and updates.
When I import the image, it seems like it is wrongly sized. The red border is very small and just show a fraction of the image.
Scaling does not help because that also scales the Red border.
Here is the strange part.
I first installed my ViaCAD Pro 9 on my Macbook Air that I mostly use. The PNG import works just fine on that. NOTE! It works on this machine.
Then I found out I wanted to have the application on my MacBook Pro Retina instead to get a larger desktop to draw on.
That is when I saw the issue.
So here is the scenario:
1. A fully working project on my MacBook Air is saved. The PNG image shows perfeclty and scales perfectly with the view.
2. I load the working file on my MacBook Pro Retina. The boundaries of the image is correct, but scaling/dpi of the image is off the chart, so I only see 1% of the image upper left corner.
I have tried different Imagesizes, different type of images (JPG, PNG, BMP). I get same issue.
Can this be a bug?
SOLUTION: Latest build of the application from tech support
/MartOn
Edited by user Wednesday, February 25, 2015 1:24:12 PM(UTC)  | Reason: Issue resolved
/MartOn
(Mac OSX 10.10.x, ViaCAD Pro 9.0.0, Ultimaker 2 3D Printer)
#2 Posted : Wednesday, February 25, 2015 2:02:58 AM(UTC)
I fixed several issues importing PNG/BMP/JPG files on retina screens.
What version of ViaCAD do you have?
TIm
marton
#3 Posted : Wednesday, February 25, 2015 2:51:04 AM(UTC)
marton
Norway
I use Version 9.0.0 (Build 1109)
The same version is tested on both macs.
/MartOn
/MartOn
#4 Posted : Wednesday, February 25, 2015 11:30:07 AM(UTC)
Hello Marton
Contact tech support and tell them your 1109 build does not support importing images on a retina machine (per Tim Olson). They will send you build 1143 which should correct the retina issue.
http://support.encore.co...frm.aspx?product_id=2820
If you have an image inside your file, you will need to delete it and re-import with the newer build.
Apple threw us developers a curveball with their APIs on retina screens. Sorry for the inconvenience!
#5 Posted : Wednesday, February 25, 2015 12:13:08 PM(UTC)
Thanks for prompt reply. Support Ticket created
marton
#6 Posted : Wednesday, February 25, 2015 1:22:03 PM(UTC)
marton
Norway
I can confirm that build 1144 solves this issue!
Thanks for the support.
/MartOn
