Rendering & Display
All objects disappear in Front view
Recently, all objects started disappearing in Front view. I see them all when I select Top, Right or any other view, but I get nothing in the Front view, in spite of trying "zoom all", various shading options, selecting four viewports, etc. The objects are there, since when I "select all" I can see their number and attributes in the Inspector, but they are not visible in the Front view. I'd appreciate some help because this is really interfering with my work. Thanks!
I have solved my problem by unchecking "Clip At Eye Point" in View / Shade Options.
G2Art attached the following image(s):
(44kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Was thanked: 503 time(s) in 353 post(s)
Good find. If the object is behind the eye point, with Clip enabled, it will not display. Your object is probably 500 units away from the origin.
Edited by user Tuesday, February 24, 2015 2:43:24 PM(UTC)
(39kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Rendering & Display
