#1 Posted : Friday, February 13, 2015 12:33:43 PM(UTC)
I updated the Flip One Normal tool to show surface orientation while you are in the flip command.
The orientation of facets is important when converting subdivision meshes to NURBs. In this video we use the Flip One Normal tool to identify and fix flipped normals. Once corrected we convert into a surface and thicken into a solid.
http://youtu.be/3McEMuH7JL8
ALBANO
#2 Posted : Wednesday, February 18, 2015 6:22:42 AM(UTC)
ALBANO
Was thanked: 28 time(s) in 15 post(s)
Hi Tim,
in 1050 the "Surface Normals Check" leaves me with a "hand cursor". I can´t select meshes.
ALBANO
#3 Posted : Thursday, February 19, 2015 8:23:32 AM(UTC)
ALBANO
Still the same in 1051.
BUT If i combine meshes and convert them to Nurbs, it works! nice!
#4 Posted : Thursday, February 19, 2015 10:35:16 AM(UTC)
[ >>"Surface Normals Check" leaves me with a "hand cursor".
Fixed in 1152. This tool takes everything displayed and does not require a selection. I also updated this to a tool palette in 1152.
Edited by user Thursday, February 19, 2015 10:35:50 AM(UTC)  | Reason: Not specified
Jean-Francois Jacques
#5 Posted : Thursday, February 19, 2015 10:47:10 AM(UTC)
Canada
Nice icons Tim!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
ALBANO
#6 Posted : Friday, February 20, 2015 3:15:54 AM(UTC)
ALBANO
I like the idea of having a UI for Powerpack! :-)
