Solid Modeling
Viacad Pro can do intersection curve as Solidworks ?
                Hello,
I would like to know whether Viacad Pro can do intersection curve as Solidworks ?
In viacad , Is  Cut Section tool the same as intersection curve ?
If yes,please tell me where I can find any explain about cut section tool by movie or photo explain.
Please refer the following links of intersection curve .
http://www.pdweb.jp/oldpdweb/techniqe/sw0907_03.shtml http://www.pdweb.jp/oldpdweb/techniqe/SW0904/hajimeSW_03_C09.JPG
 ViaCAD Pro can calculate:
--surface / surface intersection  (Surface/Surface Intersection Tool)
--infinite plane/surface intersection (Cut Section Tool)
--curve/surface intersection (Curve/Surface IntersectTool)
It also supports projections, imprints, and trimming with intersection curves.
Edited by user  Friday, February 6, 2015 12:39:20 PM(UTC)
 | Reason: Not specified
(53kb) downloaded 8  time(s). You cannot  view/download attachments. Try to login or register.
    Tim Olson  IMSI Design/Encore
                hello, thank you ,this is what I wanted to know.  !!
Solid Modeling
