                I am using ViaCAD beta 9.0.4 build 1150 (I have experienced this issue with the previous releases as well) and I seem to have a a low level of success converting STL files to solids.  At least the binary tools do not work with them after the conversion.  I select the object, right click, select change object type, select solid and click OK.  The wait cursor spins for a while and stops with no errors but does not seem to change the object.  I attached is a sample file of what I am talking about.
Thanks for any help!
Randy
Edited by user  Friday, February 6, 2015 4:23:02 PM(UTC)
 | Reason: Not specified
 Tool Chest.vcp
(196kb) downloaded 7  time(s). You cannot  view/download attachments. Try to login or register.
                Hi Randy
The limits of the Change Object Type tool inspired me to start the PowerPack project.  Change Object Type will convert a single body perfect mesh of limited facet counts.  Below is a video showing how I would use PowerPack to convert this mesh into a precise solid.
http://www.csi-concepts....emo/videos/toolChest.mp4 Tim
Edited by user  Sunday, February 8, 2015 12:14:04 PM(UTC)
    Tim Olson  IMSI Design/Encore
                Im using the beta version and I dont have the option to check a mesh for non-manifold faces..
 I just added that into the 1151 build which is not out yet for beta.   Show Free Edges and Show Non-Manifold Edges really help track down problem areas for converting meshes into precision solids.
