Jimbl
#1 Posted : Friday, February 6, 2015 3:54:41 PM(UTC)
Jimbl
Tim Is Shark LT 9 going to have the dimension glitches fixed or am i missing something? The feet and inches on windows vista machine i run measures in feet and inches but the windows 8.1 rounds the measurement down to the nearest foot i.e
23" shows a dimension of 1'
Thanks Jim
#2 Posted : Friday, February 6, 2015 6:07:17 PM(UTC)
Hi Jim
The units you have on the dimension might not be set to feet/inches but set to feet. There are two things to look at in the preferences you set the overall units to decimal, feet, feet/inches, but each dimension can be set as well. The dimension have their own setting shown in the attached picture.
Edited by user Friday, February 6, 2015 6:08:17 PM(UTC)  | Reason: Not specified
dimensions shark lt.PNG (88kb) downloaded 6 time(s).
Jimbl
#3 Posted : Friday, February 6, 2015 11:39:51 PM(UTC)
Jimbl
Hi Jason in preferences i set it to feet and inches and in the inspector i set it to for preferences. I have tried setting it to feet and inches in the inspector but it always rounds down to the foot. If i set in feet only it gives me feet and a decimal of a foot. Like i said in my original post my computer at work with the same shark lt has feet and inches working fine, the difference is its operating system is windows xp. Maybe next time i am at work i will write down all the settings and duplicate on this computer and see what happens. But i think i might have already done that.
Thanks Jim
#4 Posted : Saturday, February 7, 2015 11:42:14 AM(UTC)
Thanks Jim
Jim
Could it be the default settings in the inspector are set to use preferences, but the individual dimension is set to something else? If no geometry is selected when you change settings in the inspector it sets the default behavior. If you only select one or more objects it only changes their settings.
Jimbl
#5 Posted : Saturday, February 7, 2015 12:20:54 PM(UTC)
Jimbl
Hi Jason If it measures feet only when i check in inspector it is set to feet and inches. One thing i just noticed i have units set to feet and inches and i draw a line and i add the value 2.5' in the coordinates box, i hit enter the value goes back to 2'. I measure it using feet and inches, it measures 2'. I measure it using inches and it measures 30". Another strange thing, units set to feet and inches i draw a line watching the line length value, everything shows inches up until the 1' mark after 1' it shows fractions of an inch until i reach 1'1" then the value in the length box changes back to 1' stays that way until the line reaches 2' long.
Thanks Jim
