#1 Posted : Wednesday, February 4, 2015 3:27:15 AM(UTC)
Now I am conaidering to buy viacad pro or shark lt.
What is the difference between them?
#2 Posted : Wednesday, February 4, 2015 4:12:54 AM(UTC)
#3 Posted : Wednesday, February 4, 2015 9:27:05 PM(UTC)
Thank you for your reply .
I compare Viacad Pro with Shark LT v8 ,and I found the following function does not have Shark LT v8 but Viacad Pro have it .
Push pull modeling ,Mesh
Offset Surface
Subdivision
Woodworking Joints
Photo rendering
So , I need to carefully to check each function to consider which function I want ,and need to select Viacad Pro or Shark Lt , right ?
I thought that Shark Lt is better function than Viacad Pro but it is not true ?
aplb
#4 Posted : Wednesday, February 4, 2015 9:38:40 PM(UTC)
aplb
On the other hand,there is the Shark Lt v8 have ,and Viacad Pro does not have ?
Auto 3D to 2D(Precise)
GD&T
MakeUp and Redline
MicroScribe Digitizer
#5 Posted : Wednesday, February 4, 2015 11:18:19 PM(UTC)
Shark LT 9 has all the features of ViaCAD Pro 9 plus more. I think you are comparing a V9 product with a V8 product.
Something else you might want to consider is that Shark LT 9 is about to be released and will be 64 bit.
Edited by user Wednesday, February 4, 2015 11:24:34 PM(UTC)  | Reason: Not specified
#6 Posted : Thursday, February 5, 2015 5:00:35 AM(UTC)
so, I need to wait until v9 release , or if I buy v8 shark lt and free upgrade it ?
aplb
#7 Posted : Monday, February 9, 2015 3:11:39 AM(UTC)
aplb
if I buy shark lt v8, will it be free upgrade because v9 coming soon,
or usually how much upgrade v8 from older version.
additionally,I would like to know whether it is possible to upgrade from viacad to shark lt?
Guest (6)
