how or what setting do I need to change so that after drawing a sketch, when i go to dimension the lines. they stay connected at their endpoints. right now when i set a length, the changed line breaks connection with the other lines. thanks for any help
Originally Posted by: mnmetalfab how or what setting do I need to change so that after drawing a sketch, when i go to dimension the lines. they stay connected at their endpoints. right now when i set a length, the changed line breaks connection with the other lines. thanks for any help
Hello
It sounds like you have selected a line and changed its length. Are you trying to change the dimension value to something different than the true value of the line that was drawn?
If you are trying to change the dimension value other than default you have to select the dimension, hit ctrl I or open the inspector by right clicking on the dimension number and picking inspector. Then clear the # out and put what override value you want.
Edited by user Saturday, January 31, 2015 9:04:46 AM(UTC)
(16kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
that worked , but it keeps the line angles and lengths of the other undimensioned lines the same. is that something that i have to dimension as im drawing, before the other liines are drawn in?
Originally Posted by: Guest that worked , but it keeps the line angles and lengths of the other undimensioned lines the same. is that something that i have to dimension as im drawing, before the other liines are drawn in?
What program and version are you using?
The drawing of objects and lines should not effect dimensioning and dimensions should not effect anything that is drawn. Draw all your geometry to the size you want then add dimensions last after everything is drawn.
Can you post a pic of what is happening.
