Solid Modeling
Add Solid Retains original Parts
                When I split a solid and use the "add solid" command I end up with 3 parts. I found it on my fairly complex parts and confirmed it on a rectangular extruded solid. Is this a bug or a new feature? Art FX 9.02 Mac 10.10.1
                Can you post a short file?
                Does this not happen to you?
I am on 9.0.2 1143
Art
Edited by user  Friday, January 16, 2015 10:24:11 AM(UTC)
 | Reason: Not specified
 FinderScreenSnapz002.mov
(1,581kb) downloaded 15  time(s). You cannot  view/download attachments. Try to login or register.
                I don't think this is a bug but rather a setting that is backwards.  If you look at the add solid command under the inspector-> data you can see if the hide parents is active.  This is a new feature where you can go back and unhide the originals for whatever reason.  In your case the two pieces.
                I see! Thanks for the help. So the default is set to show parents. I assume I can see my personal default to hide them, correct? Art
                 Hi Art The default should be set to hide parents. Tim
    Tim Olson  IMSI Design/Encore
                Thanks Tim, nice to have a choice. Art
Solid Modeling
