Morphin
#1 Posted : Tuesday, December 30, 2014 2:47:49 PM(UTC)
Morphin
Hi
I need help! I can't manage to move the 2 brackets for the roof 0.5mm away (outside). Actually i need only to move the rod of the brackets, not the end.
Hmm. I'm desperatly need a hint. Please have a lock at my file.
Thank's for every help
Andy
GPSHolder.zip (1,280kb) downloaded 3 time(s).
Morphin attached the following image(s):
rokoko
#2 Posted : Tuesday, December 30, 2014 3:16:26 PM(UTC)
rokoko
hi,
try the tool "remove face" first to remove blends
Morphin
#3 Posted : Tuesday, December 30, 2014 3:37:01 PM(UTC)
Morphin
o.k. I will try that
Andy
Now PUSH/PULL will get a new surface.... instead of moving the face
-now it works...!!!!
Edited by user Tuesday, December 30, 2014 3:41:27 PM(UTC)  | Reason: Not specified
