macnavi
#1 Posted : Monday, December 29, 2014 4:24:38 AM(UTC)
macnavi
Netherlands
When extruding text with draft, the whole process with a sentence fails when a letter has a hole in it, like R, O, P, A or when the draft is too high that both sides of the leg of a letter would overlap it each other. It brings up the error: "ACIS error: Rigid sweep with draft". I don't mind if they would overlap.
Is there something I can turn off so that it allows me to overlap the draft? Like you can do Pipe options, "Allow Self Intersection".
Using ViaCad 8 2D/3D (9 has still too much bugs to be functional) and Mac OS X Yosemite.
#2 Posted : Monday, December 29, 2014 5:00:09 AM(UTC)
One workaround is to extrude text with rhino3d and export as acis 4.........
just my 2cts
regards
- Bernd -
Edited by user Monday, December 29, 2014 3:31:00 PM(UTC)  | Reason: wrong acis version number
#3 Posted : Monday, December 29, 2014 1:16:31 PM(UTC)
Try converting the text to curves from object type than do each one individually. There's a limit that draft can do with letters until wall will start to collide. Maybe doing it individually avoids the error.
