flatpack
#1 Posted : Friday, November 14, 2014 11:39:16 AM(UTC)
flatpack
This may have been covered in posts eons ago and if so please show me a link.
Otherwise.. trying to understand the difference between Thicken and Extrude? I only ever use Extrude. Is Thicken a feature primarily for surface modeling?
Thanks!
-flatpack
#2 Posted : Friday, November 14, 2014 1:43:19 PM(UTC)
Extrude will take a closed collection of curves and sweep the curves along a straight vector creating either a surface or solid.
Thicken will take a surface, offset it, and fit new orthogonal side faces between the copies. The result is a solid.
Extrude ->rigid sweep
Thicken ->offset (result is everywhere perp)
A somewhat hidden feature of the thicken tool is that it will work with a solid. If you select the entire part, it will add thickness to the entire part. You can also select an individual face to thicken. Plus this tool will accept a negative value for the thickness.
L. Banasky
#3 Posted : Sunday, November 16, 2014 6:04:32 AM(UTC)
L. Banasky
Was thanked: 157 time(s) in 107 post(s)
I've been using the Thicken Tool for lengthening and shortening angle iron, I-beams and even complicated shapes as 8020 aluminum extrusions.
It works great and is a real time saver. Thanks Tim.
flatpack
#4 Posted : Thursday, November 20, 2014 9:55:24 PM(UTC)
flatpack
Thanks for the detailed explanation Tim!
-flatpack
