Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
This may have been covered in posts eons ago and if so please show me a link. Otherwise.. trying to understand the difference between Thicken and Extrude? I only ever use Extrude. Is Thicken a feature primarily for surface modeling? Thanks! -flatpack
Was thanked: 503 time(s) in 353 post(s)
>> the difference between Thicken and Extrude? Extrude will take a closed collection of curves and sweep the curves along a straight vector creating either a surface or solid. Thicken will take a surface, offset it, and fit new orthogonal side faces between the copies. The result is a solid. Extrude ->rigid sweep Thicken ->offset (result is everywhere perp) A somewhat hidden feature of the thicken tool is that it will work with a solid. If you select the entire part, it will add thickness to the entire part. You can also select an individual face to thicken. Plus this tool will accept a negative value for the thickness. Tim
Thanks: 171 times Was thanked: 157 time(s) in 107 post(s)
I've been using the Thicken Tool for lengthening and shortening angle iron, I-beams and even complicated shapes as 8020 aluminum extrusions. It works great and is a real time saver. Thanks Tim. Larry
Thanks for the detailed explanation Tim! -flatpack
