Suggestions
context-menu, ambiguity, right click (#5220)
hi, everybody knows context-menu (right click..) on an object well. but if there will be an ambiguity popup, you need a left click first to select your object - in ambiguity no right clicks are accepted. not very nice! could we get right click working in there? would be very handy.. thank you, regards beta 1130, mac os 10.8
Thanks: 224 times Was thanked: 175 time(s) in 106 post(s)
Hi Rokoko, I support your request ! From Sulzbach an Taunus...
Ok. Try this out in 1132. Tim
thanks! works like a charm
Before was about the same thing...now you have the same action for the right and left click! Is it right? Before -Left click = ambiguity popup= right click on model name = contextual menu Now- Left click = ambiguity popup = right or left click on model name = contextual menu
no, look: if you want a context menu, what would you do? a right click on an object - so far, so good. but what - if you have crowded objects - what happens with your right click? an ambiguity popup pops up. next? in former times you were forced to click left to get your context menu. now you are free to click right or left while you are inside popup . that's it!
Yes Rokoko, was the right click only and now the right and the left is good!
unfortunately that handy "right click" inside ambiguity popup is no more working... why? build 1157 mac os 10.6.8 regards
hi, after playing around a bit i can state that right click inside ambiguity menu is working in mac os 10.8.5. the problem only exists in a 10.6.8 installation i sometimes use. regards.
Suggestions
