Suggestions
opening and closing Viacad (#2493)
                If I exit viacad, I don't want to have to reboot to be able to open it again like I do now.  Obviously it does not leave memory cleanly and rebooting simply so I can use it again is a flaw in the system.
                Originally Posted by: jfc1068  If I exit viacad, I don't want to have to reboot to be able to open it again like I do now.  Obviously it does not leave memory cleanly and rebooting simply so I can use it again is a flaw in the system.
Hi jfc
What operating system are you using?  Right click on the ViaCAD icon and goto properties then goto compatibility tab and check the run as windows xp.
(26kb) downloaded 3  time(s). You cannot  view/download attachments. Try to login or register.
                I'm running Vista.  Thanks for the input, but that still did not fix the issue.
                Originally Posted by: jfc1068  I'm running Vista.  Thanks for the input, but that still did not fix the issue.
hi jfc
do you get any error message when you close ViaCAD?  Or what happens when you try to restart?
                nothing happens except the hourglass appears breifly before, nothing....
                HI jfc when you changed the properties in the icon, did you hit apply before closing the box?  I am running Vista and ViaCAD 2d v5 and have not seen an issue with open close. Regards Jason
Suggestions
