jfc1068
#1 Posted : Saturday, August 8, 2009 6:29:49 AM(UTC)
jfc1068
I want to be able to cancel a function when it does not do what I want. Is there not a simple way, like pressing the esc key, to do this?
Shouldn't this be in the manual?
#2 Posted : Saturday, August 8, 2009 7:47:42 AM(UTC)
The selection tool might help a little. You can also assign a shortcut key to the selection tool. I use the q key. Goto file menu --> Short Cuts... Then in the dialog box on left goto category tools then in the Selection box on the right pick selection then assign a key. You can save shortcuts to different names as well so you have a lot of options. it is case sensitive so uppercase vs lower is different keys.
#3 Posted : Saturday, August 8, 2009 11:24:35 AM(UTC)
Yep - Selection = back to neutral
