2D Drafting
cancelling a command (#2490)
I want to be able to cancel a function when it does not do what I want. Is there not a simple way, like pressing the esc key, to do this? Shouldn't this be in the manual?
Originally Posted by: jfc1068 I want to be able to cancel a function when it does not do what I want. Is there not a simple way, like pressing the esc key, to do this? Shouldn't this be in the manual?
The selection tool might help a little. You can also assign a shortcut key to the selection tool. I use the q key. Goto file menu --> Short Cuts... Then in the dialog box on left goto category tools then in the Selection box on the right pick selection then assign a key. You can save shortcuts to different names as well so you have a lot of options. it is case sensitive so uppercase vs lower is different keys.
Yep - Selection = back to neutral
2D Drafting
