XL5
#1 Posted : Monday, February 28, 2011 2:00:13 PM(UTC)
XL5
I am working on a drawing imported from AutoCAD.
The objects that I create, I have no trouble manipulating. But there are some objects in the original AutoCAD drawing that I simply want to move.
I find that when I drag across the area of the object, the object will turn red, indicating that I have successfully selected it.
I can take that selected object and Copy it, or Delete it. I simply want to MOVE it using the mouse. But the darn thing won't budge!
The object in question is a simple group, consisting of just two lines in a circle. I don't want to un-group this object, because I will have to put it back together again. I want to move the entire group with the mouse.
I suspect that somehow this object has dependencies (whatever that is). How can I move this object with the mouse?
#2 Posted : Monday, February 28, 2011 3:04:41 PM(UTC)
try edit>remove links first
alternatively edit>change object type to lines might help
as for the full explanation of why - 'fraid I can't remember !
XL5
#3 Posted : Monday, February 28, 2011 7:39:41 PM(UTC)
XL5
Greetings from the Colonies.
I tried both:
edit>remove links
edit>change object type to lines (it already was 'lines').
Neither worked.
On the objects that I have created, once I select that object I then hover the mouse over that object. The mouse pointer turns into a 4-arrowed pointer. Once I have the 4-arrowed pointer I can easily drag that object precisely where I want it.
I never get the 4-arrowed pointer with the object you are helping me with.
Something else happens that may give us a clue. I can very easily select objects that I have created by simply clicking anywhere on that object (precise pointing is not necessary). With the objects I'm having difficulty with I cannot simply click on that object, I MUST drag over it with the mouse pointer in order to select it.
Other suggestions are welcome, there's got to be a way to do this.
#4 Posted : Tuesday, March 1, 2011 1:10:39 AM(UTC)
Hi - can you post it please ?
I'm sure we can get to the bottom of it
(I do remember such a problem with lines that made up polygons - but I don't think that's the case here)
XL5
#5 Posted : Thursday, March 3, 2011 3:20:51 PM(UTC)
XL5
Todd, at Punch Software support found the problem.
To make all these problems go away, all I had to do was:
Go to the ViaCAD pull down menu and select "Preferences". Once in the dialog box, click "Factory All". This resets the preferences back to install defaults.
I have only done a quick check, but this appears to have solved the problem.
Is there any particular setting in the preferences that may have caused this? In other words, what should I NEVER do again?
Todd was terrific, he stayed with my problem for several days, e-mailing various suggestions. Through this process I never got discouraged because Todd at Punch Software continued to work the problem.
Bear in mind, I purchased the lowest cost ViaCAD software available, but I was treated like I spent $5000.
In the future, I now plan to upgrade to more powerful versions of ViaCAD.
Guest (6)
