Surface Modeling
Why cant I get a clean surface? (#3993)
the wires in this file are port cross sections. They have been manipulated by me. I either need to be able to make them into a solid, or skin the outside, but when I do it gets all twisted.
What am I doing wrong.
I have been able to do about anything I needed to do for the 6 years I have been using the software, but this is something new I have just ran into.
I think part of the problem is the line is broken up into too many sections. is there a way to turn it into one line?
thanks
Charlie Westcott.
sample.vcp
(119kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
HI Charlie Did you try to group the lines together at each cross section? Regards Jason
just did, I have never done that. It still twists it.
Charlie What tool are you using "skin solid"? Regards Jason
yes, skin sold. I cant figure out how to wrap a surface around it. Either would work.
Thanks: 33 times Was thanked: 24 time(s) in 21 post(s)
Join the curves with "join curve" tool instead grouping them, and then use the skin solid tool with perpendicular skin option selected, see the attached img.
Luis G.
[ATTACH]4081[/ATTACH]
(99kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
I have VC pro, it doesnt have the U and V check boxes that yours has. And when you skin it it has funny diagonals going from one wire to the next.
I guess I was wondering if I bought the next version, or shark would it work better for what I am doing.
warfish3651 attached the following image(s):
(48kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Surface Modeling
