                Is there any chance that the Intersect Solid tool could be given a similar function to that already available in the Subtract Solid tool, which would allow the retention of all three parts by pressing the CTRL key at the time of execution?  It would save me some fiddling about for certain jobs I do every now and again. Martin.
                you mean like "DIVIDE" at intersection?
                Originally Posted by: misterrogers  you mean like "DIVIDE" at intersection?
Yes, I think that's it. I'd find it a useful addition to the toolkit for chopping up parts easily.
But after a little more investigation, I've found that the Split Solid tool does actually do this, but in a slightly more involved way. Taking 2 intersecting sphere primitives and using the Split Solid tool on them. Select the first sphere. You are then asked for a SURFACE to use for the split, but as there isn't one you should select the other (solid) sphere. Now what I was hoping for, was for VC to leave the first sphere with an impression of the second sphere in its surface, along with the split (lens shaped) part - and indeed it does. What I didn't expect was that VC would create a duplicate of the second sphere, complete with impression of the first sphere, and ALSO leave the original second sphere in place. The VC help feature gives no indication that the tool can be used with solids, or that it retains the difference between parts etc, when used as above.
Martin.
                Originally Posted by: blowlamp  Is there any chance that the Intersect Solid tool could be given a similar function to that already available in the Subtract Solid tool, which would allow the retention of all three parts by pressing the CTRL key at the time of execution?  It would save me some fiddling about for certain jobs I do every now and again. Martin.
Martin
Try selecting your solids, goto to Verify --> Interference..., and check the box at bottom keep intersection solids.  Is this what you are looking for?
(9kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: jdi000  Martin Try selecting your solids, goto to Verify --> Interference..., and check the box at bottom keep intersection solids.  Is this what you are looking for? Regards Jason
Jason.
It isn't exactly what I'm looking for, but it is something I wasn't aware of and having tried it, I think it's something that should be made a little more prominent and put with the other solid manipulation tools. With a bit of imagination you can come up with all sorts of shapes by using it. Thanks for your help.
After a bit more digging, I've found that other solids don't seem to work in the same way as spheres when weilding the Split Solid tool, and the second selected item doesn't appear to get modified in the way it would if it were a sphere :(.
So my original request still stands for a slight tweak to the Intersect Solid tool, please.
Martin.
Thanks: 76 times Was thanked: 91 time(s) in 59 post(s)
                Hi BL, This is EXACTLY what i experienced, and i got confused... I need to go back and see whether i was ignoring the "Keep intersection solids" option and see if i can get the empty volume to become the reverse of the surface i want... Thanks for pointing out your post to me.
                I was hoping that the Intersect Solid tool could be tweaked, to allow the production of things like the 3 parts in the lower part of the picture from the blue solids in the upper part, with just a couple of clicks. As it stands at the mo', I have to make multiple copies, dice them up and then delete what I no longer need.
Martin.
(49kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
                One extra copy of each will do.  Intersect first, then subtract the intersect from the originals, keeping the intersection.
