MadOverlord
#1 Posted : Wednesday, July 24, 2013 6:37:24 PM(UTC)
MadOverlord
Let's say I drill a hole in one of my parts. Later I decide I want to countersink that hole.
When I use the hole tool and select the surface and the center of the current hole, it asks me if I want to project the point, and regardless of whether I do or not, the new hole is offset.
How can I redrill the hole?
billbedford
#2 Posted : Thursday, July 25, 2013 2:44:09 AM(UTC)
billbedford
You go to Inspector -> Object Properties -> Data and change the hole type to Countersink
MadOverlord
#3 Posted : Friday, July 26, 2013 8:27:28 AM(UTC)
MadOverlord
Unfortunately, this won't work for me. Either the hole is now a part of a solid or it was created by intersecting two solids, so there is no hole object to modify.
I have tried all sorts of methods, including drawing a new circle on the solid surface I want to drill, but the result is always offset.
Sorry for not providing the above details in my OP
billbedford
#4 Posted : Saturday, July 27, 2013 2:26:34 AM(UTC)
billbedford
You mean your solid is now an ASIC solid?
Then chamfer the edge of the hole, or subtract a cone if the hole is in a non-plane surface.
rockyroad_us
#5 Posted : Saturday, July 27, 2013 9:05:10 AM(UTC)
rockyroad_us
If an ASIC solid, you can just remove the hole with the remove face tool. You can just put a guide so that you know where the previous hole was and redo a new type of hole in the same spot.
