[FONT="Verdana"]I'm looking for help in making a screw thread on a solid cylinder object. Thanks, linpwer[/FONT]
I start with a cylinder a given diameter. Make a helix with the same diameter at the center point long the length of my cylinder. I make a surface profile of the thread. I extrude the profile along the helix. I can adjust the pitch of the helix to work out my thread spacing. The I can resize the thread depth by modifying the associated thread profile. To finish out a bolt I chamfer the end of the cylinder. I then will do a tapper of the bolt thread by creating a long arch from the end face of the thread to the surface of the cylinder. I select the face of the ending thread and extrude the face profile to along the arch so thread tappers out onto the face of the cylinder. Hope this helps.
I must not be doing something right with the thread profile. Everytime I try to sweep or extrude the profile I get an ACIS Error of "The helical sweep results in a self-intersecting body. :confused:
I did it. :) I had to create three helixes all on the same axis as the cylinder. I first made a helix for the major diameter of the screw thread. Then a helix with the minor diameter of the screw thead that starts at 1/2 pitch from the start of the first helix. The third helix is with the major diameter of the screw thread, but starts at the pitch distance from the first helix. I made a surface with helix 1 and helix 2, then a second surface from helix 2 and helix 3. Next join the two surfaces. Then subtract the surface from the cylinder, which gave me an internally threaded solid. I made a new solid cylinder and subtracted the internal thread. I had to make the chamfer on the end of cylinder prior to subtracting the thread material. If tried to chamfer one end of the cylinder after subtracting the tread material, I received an error message.
The method I used to create a screw thread in a cylinder is still not quite right. I seem to get a good render but the result with I select the Model to Sheet is not of much use.:confused: I attached a jpg file of the rednering of the screw thread and a pdf file of the Model to Sheet results.
If someone has a method that also gives a good model to sheet result, that would be great.
M3X0.5Thread_SheetDrawing.pdf
(100kb) downloaded 5 time(s). linpwer attached the following image(s):
(72kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Try elevating the curves You used for the surfaces. If that doesn't work try splitting up the solid before using the model to sheet command. Ciao, Norbert
Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
I make a lot of threads and I always use one hellix only and a swept profile.
You can find an example file on the old forum, (I still have issues to attach stuff to this one) :
http://csi-concepts.com/conceptsunli...hp?p=9258#9258 This one is a "negative" screw used to make a threaded bore in a bloc by boolean substract.
I hope it helps,
JL
