hallo,
how can i make a solid with the splines i made. please see the attachment.
usually it is going very easy for me, but in this case i do have a hole in my mind.
All the survaces i made will not come together.
thank you
Andreas
ring.vcp
(148kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
I have a solution here - not sure if it's exactly what you want - just by making more patches. There's a tricky transition going on in there
Jol
Jolring.vc3
(163kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
thank you Jol, it is exactly what i need . is there any reason for the surface with the no: Surface_2273 ?
no : ) I thought it might control it better to cut a centre-line section - and include that in the network surfaces - I didn't do it in the end - bit it may give you better tangency - depends how far you need to take it Jol
o.k. i see, there is a lot more to learn for me. thank you :-)
I've had a go too :)
Martin.
ringskinsolid.vcp
(165kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
the network surface tool often gets you out of trouble - it is the most flexible of the surface tools endpoints and junctions dont actually have to meet - as with other tools and you can have as many cross-curves in 'm' and 'n' (direction) as you like (you need more cross-curves for more control) the NS tool accepts part-curves, grouped curves and even points as input I'm really a fan !
very nice. this solution is a great help for me. And it is so simple, i wonder that i could not find out this way.
