awieneke
#1 Posted : Thursday, June 30, 2011 4:20:54 PM(UTC)
awieneke
hallo,
how can i make a solid with the splines i made. please see the attachment.
usually it is going very easy for me, but in this case i do have a hole in my mind.
All the survaces i made will not come together.
thank you
Andreas
ring.vcp (148kb) downloaded 5 time(s).
#2 Posted : Friday, July 1, 2011 1:29:26 AM(UTC)
I have a solution here - not sure if it's exactly what you want - just by making more patches. There's a tricky transition going on in there
Jol
Jolring.vc3 (163kb) downloaded 5 time(s).
awieneke
#3 Posted : Friday, July 1, 2011 4:10:22 AM(UTC)
awieneke
thank you Jol,
it is exactly what i need .
is there any reason for the surface with the no: Surface_2273 ?
#4 Posted : Friday, July 1, 2011 4:30:07 AM(UTC)
no : )
I thought it might control it better to cut a centre-line section - and include that in the network surfaces - I didn't do it in the end - bit it may give you better tangency - depends how far you need to take it
Jol
awieneke
#5 Posted : Friday, July 1, 2011 4:37:15 AM(UTC)
awieneke
o.k. i see, there is a lot more to learn for me.
thank you :-)
blowlamp
#6 Posted : Friday, July 1, 2011 5:07:04 AM(UTC)
blowlamp
I've had a go too :)
Martin.
ringskinsolid.vcp (165kb) downloaded 5 time(s).
#7 Posted : Friday, July 1, 2011 5:09:15 AM(UTC)
the network surface tool often gets you out of trouble - it is the most flexible of the surface tools
endpoints and junctions dont actually have to meet - as with other tools
and you can have as many cross-curves in 'm' and 'n' (direction) as you like
(you need more cross-curves for more control)
the NS tool accepts part-curves, grouped curves and even points as input
I'm really a fan !
awieneke
#8 Posted : Friday, July 1, 2011 1:55:07 PM(UTC)
awieneke
very nice. this solution is a great help for me. And it is so simple, i wonder that i could not find out this way.
