2D Drafting
Curve cut/split rules? (#2339)
What are the "CAD" rules for being able to split / trim curves, other than the obvious "they must intersect" rule? Are Groups or Blocks of curves not good to try and slice and dice? Anything else? Thanks!
Originally Posted by: Tem What are the "CAD" rules for being able to split / trim curves, other than the obvious "they must intersect" rule? Are Groups or Blocks of curves not good to try and slice and dice? Anything else? Thanks!
Not really mate :( have you looked at the help any ?
VC desperately needs the ability to window select geometry in order to trim/split multiple items in one go ? It's very very painful and long winded at the minute..Tim is this on the agenda for change ?
>>VC desperately needs the ability to window select geometry in order to >>trim/split multiple items in one go ? It's very very painful and long winded >>at the minute..Tim is this on the agenda for change ?
Paul, no activity here. When I trim a bunch of stuff, I usually double click on the arrow tool to select all, then select the trim tool and just click the pieces to remove. Or if its a area, I will use the region trim command.
http://www.csi-concepts.com/Demo/videos/trim.mov Is that what your looking for or something else?
2D Drafting
