Tem
#1 Posted : Thursday, January 17, 2008 12:56:19 AM(UTC)
Tem
Concepts 4 SP3 on Mac Intel.
I upgraded to Leopard recently.
When I click on the icon in the dock or on the .app file in the concepts folder
an error message is displayed.
What is the easiest way to get Concepts running again?
Thanks.
nick
#2 Posted : Thursday, January 17, 2008 5:09:58 AM(UTC)
nick
Hello Tem
You probably need to re-install Concepts as it stores some libraries within the Mac OS X system which tend not to get copied when you do an upgrade or archive and install.
All the best
Nick
RC-Modeller
#3 Posted : Thursday, January 17, 2008 9:40:27 AM(UTC)
RC-Modeller
Hello Tem
I had a similar problem (maybe the same??), Try this:
1.) open your application folder
2.) open your concepts folder
3.) search for the concepts application and mark it (one click)
4.) choose get info from the file menu
5.) select open with Rosetta support (it may sound stupid but it worked for me)
6.) try to start concepts again
I hope it works for you as well as it did for me!
All the best
Hans
Tem
#4 Posted : Thursday, January 17, 2008 10:41:21 AM(UTC)
Tem
Thanks guys.
I think I'll just back-up a few files, erase Concepts and reinstall it.
I think that erasing the old system folder is what caused the problem.
So, where do I go and download the most recent version of Concepts again?
Thanks.
Tem
nick
#5 Posted : Thursday, January 17, 2008 3:04:29 PM(UTC)
nick
Hello Tem
You can download from our website at the following URL:
http://www.cadsoftsolutions.co....ed/download/download.php
You will have to complete form first though I'm afraid.
All the best
Nick
#6 Posted : Saturday, January 19, 2008 2:59:32 PM(UTC)
>>You probably need to re-install Concepts as it stores some libraries within >>the Mac OS X system which tend not to get copied when you do an >>>upgrade or archive and install.
Yes, Nick is correct. The Apple upgrade/archive does not copy all the files required for our software. Reinstalling puts the missing file back.
NickB
#7 Posted : Monday, January 21, 2008 2:49:43 PM(UTC)
NickB
When I installed 10.5 a few alias were broken.
Try removing CU from your dock, and then go to the applications folder, click on CU and drag it back into your dock. This should fix the link and everything will work again.
Shark FX 9 build 1143
OS X 9.5
matter.cc
