Tem
#1 Posted : Wednesday, May 19, 2010 12:26:43 AM(UTC)
Tem
Can the ViaCad and Shark products be driven by Apples Automator?
I couldn't find any mention.
Thanks!
#2 Posted : Wednesday, May 19, 2010 1:08:28 AM(UTC)
not in any useful way
Tem
#3 Posted : Thursday, May 20, 2010 12:18:32 AM(UTC)
Tem
Bummber. I was hoping to script several actions into a batch file process. I had 160 DWG files to translate into DXF. The problem is that the lines are all white, and there is no way to change white to black for Text, lines & curves or, if fill then white fill to black fill. Its a favor so the hours are a no go. Maybe next rev? wish us luck.:-)
#4 Posted : Thursday, May 20, 2010 1:21:21 AM(UTC)
I believe there is a batch translate operation in Shark V7. It may help a bit
nick
#5 Posted : Thursday, May 20, 2010 9:41:58 AM(UTC)
nick
just a thought but you might be able to accomplish by setting up a startup.dat file with predefined layer colours then all you would need to do is import files and save.
all the best
nick
