Tem
#1 Posted : Monday, October 14, 2013 10:59:18 AM(UTC)
Tem
Hi All,
I was exporting a simple part as an STL (ASCI).
Normal Deviation was set to 3.0, this setting increased the mesh density (this should improve output quality on my Form1 3d printer).
Adjust Nodes and Adaptive Facets were checked.
When attempting to modify the Edge Length, it seems that the dialog process quits, returning me to work on the part as normal.
I'm not sure if this is normal and I'm not understanding the parameters for this setting.
Thanks Tim and others in advance for your response.
Tem
la mouche
#2 Posted : Tuesday, October 15, 2013 2:22:05 AM(UTC)
la mouche
#3 Posted : Tuesday, October 15, 2013 3:53:09 PM(UTC)
Hi Tem
I found/fixed a repaint issue when displaying the mesh, but I cannot repeat the issue below.
>>it seems that the dialog process quits, returning me to work on the part as >>normal.
Tem
#4 Posted : Wednesday, October 16, 2013 12:15:46 AM(UTC)
Tem
Hi Tem
Thanks for looking into that issue. I'll try to repeat.
Tem
Tem
#5 Posted : Wednesday, October 16, 2013 12:29:12 AM(UTC)
Tem
It is not occurring any more. Maybe, it was something else causing the odd behavior?
Thanks for looking into the issue.
Tem
#6 Posted : Wednesday, October 16, 2013 12:30:33 AM(UTC)
Tem
I was not able to repeat the weird dialogue box issue with the same part.
Thanks for looking into the issue, Tim.
Tem
