Solid Modeling
Associative Duplicates Not Working With Undo (#416)
I have some associative duplicates, and they "update" to show a boolean added to a part. But when "undoing" the boolean, The "master" part changes, but the boolean stays on the associative duplicates, so they have to be re-duplicated. Is there any way to "force" the duplicates to update? Or is this a Bug? Mac 10.4.9, Concepts v4 sp3 build 660 Thanks, Dave
Basically the "resolve links" option is not available after an undo.
Was thanked: 503 time(s) in 353 post(s)
>> Is there any way to "force" the duplicates to update? If you open up Concept Explorer, select the part, then right click you should see a force update for the part. These will regenerate (rebuild) a part whether it needs it or not.
Solid Modeling
