Arketype
#1 Posted : Tuesday, July 3, 2007 8:26:23 AM(UTC)
Arketype
I have some associative duplicates, and they "update" to show a boolean added to a part. But when "undoing" the boolean, The "master" part changes, but the boolean stays on the associative duplicates, so they have to be re-duplicated.
Is there any way to "force" the duplicates to update? Or is this a Bug?
Mac 10.4.9, Concepts v4 sp3 build 660
Dave
Arketype
#2 Posted : Tuesday, July 3, 2007 9:32:49 AM(UTC)
Arketype
Basically the "resolve links" option is not available after an undo.
#3 Posted : Tuesday, July 3, 2007 10:15:42 AM(UTC)
If you open up Concept Explorer, select the part, then right click you should see a force update for the part. These will regenerate (rebuild) a part whether it needs it or not.
