Verify: Properties Crash (#456)
Using verify properties in SP3 (660) crashes consistently. Even if the selected object is just a simple cube. Mac PPC G5 OS 10.4.10
Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
Arketype, It doesn't crash with me, even with complex solids... The guys will need more information :confused: JL
Attached is a simple 1" cube that crashed when choosing "properties", and the associated crash report.
verify: properties is crashing every time I try to use it.
Dave
CrashReport.txt
(28kb) downloaded 4 time(s). Cube.cu
(7kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Your cube verifies perfectly on my MacPro (2 x quadcores). On my old G4 it also works OK. No doubt your crash is linked to your hard/soft configuration. It needs to be punched! JL
Works here fine too (in ViaCAD), however i had the same probleme a while ago in ViaCAD and i fixed it by deleting a (preference or was it the override.ini, sorryi cant remember!) file. Regards Stefan
I deleted all CSI preferences and now it's working. Thanks for the help.
Arketype, I have the same problem with the verify properties tool. What exactly was your fix to the problem. Appreciate the help. thx.
