Does anyone know what this error message means? (see pic). I'm trying to shell a half pipe spiral and this appears.
Cheers
darkstarh attached the following image(s):
(39kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                This usually means you are trying to create a shell with a wall thickness which is too thick for the component.  For example if you have a pipe with OD of 10mm and try to shell with wall thickness of 6mm.
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
