Solid Modeling
Emboss surface/ Bad curvature error??? (#1819)
                Hi All,
I'm trying to emboss a pattern on a cup but every time I try to shell the final solid I get a 'bad curvature, unable to shell' message.
I create the pattern to be embossed as separate solids, pushed into the main body solid, then add all the solids together and try to shell the single piece at 1mm offset.
I've tried every solution I can possibly think of and am still having no luck.
If anyone has ideas it would be a huge help!
darkstarh attached the following image(s):
(34kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                My instinct is that you would need to union (add) the detail AFTER the shell as it is very fine (small).
                Originally Posted by: darkstarh  Hi All,
Hello darkstarh,
Your model looks fairly simple. If you are bot too fussed about the embossed detail coming thru on the shell, I would suppress or add this later to the shelled part.
Can you post a ViaCAD file or ACIS solid for us to look at ?
                Dan - sorry to fob you off today .. If you still don't have a solution by Sunday - I will try to help you then .. just had a job end today
Solid Modeling
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
