#1 Posted : Tuesday, November 1, 2011 10:58:18 AM(UTC)
FYI
If you are in a bind and need an answer right away, you can contact PunchCAD technical support. The technical support number is:
1-800-856-9601
Michael Tuttle
#2 Posted : Friday, May 3, 2013 8:18:42 AM(UTC)
Michael Tuttle
Hello,
I have been running ViaCAD Pro v8 on my Windows Vista OS for a couple of months now and until this week it has run fine. Now it takes approximately 40 minute to start up. After I exit, I have to go to task manager and end the process manually. Also, it is not saving my preferences.
I uninstalled the program, and reinstalled, but nothing changed.
Is there an e-mail for tech support?
Please let me know what I can do to fix these issues.
Michael Tuttle
posh.de
#3 Posted : Tuesday, May 7, 2013 5:57:32 AM(UTC)
posh.de
install a working OS as e.g. W7 :eek: (check Amazon/eBay for cheap OEM/SystemBuilder lics.)
if launching VC lasts 40 mins. there's something totally broken with your system. For evaluation purposes you may try to disable/uninstall your security suite or launch Windows to 'safe mode' by hitting F8 during system startup.
hth,
Norbert
Michael Tuttle
#4 Posted : Tuesday, May 7, 2013 11:25:51 AM(UTC)
Michael Tuttle
Thanks Posh.
Funny thing though, I uninstalled Pro v8 and re-installed Pro v7 and it works fine.
Mike
