MarkS
#1 Posted : Monday, January 14, 2013 12:36:38 PM(UTC)
MarkS
Once you've applied a material, is there any way to determine what it is so that you can re-use it? Outside of taking good notes at the moment you applied it, of course :) The material tab doesn't tell you what material has been applied, just angle, height, and width.
Or, better yet, is there a way to set a material to be the same as an existing material?
Thank you!
Mark
