appli
#1 Posted : Monday, December 3, 2012 8:41:25 AM(UTC)
appli
Hello,
via cad has problems of precision. For example a line in 330 degrees is in reality 329, xxxxxx. is it always necessary to type 6 numbers after the comma "330,000000" to have degrs really 330?
Shark, the same problems?
#2 Posted : Monday, December 3, 2012 12:13:20 PM(UTC)
Originally Posted by: appli Go to Quoted Post
Hello,
I don't see that on Shark.
"330" is "330", or "-30" !
BPL-RFE
#3 Posted : Monday, December 3, 2012 3:08:11 PM(UTC)
BPL-RFE
Hello.
Did some Tests.
Was able to have 1 Time your result under Viacad V7 Pro Build 967 on
Windows XP, but never again, regardless of version and what i tried ...
Which Version/OS you are on ?
Maybe a round off/snap problem ?
What Units do you use ?
How many decimals ?
Do you use Komma or Point (localization) ?
How big is your snap radius ?
Repeat what you have done and try to keep track of these settings.
Maybe this thing can be tracked down ...
Roland
appli
#4 Posted : Tuesday, December 4, 2012 11:57:44 PM(UTC)
appli
Viacad V8, windows 7 64, and viacad 6 on mac intel.
I have un old turbomac, only 3D, it's like viacad pro, with surface modeling.
