2D Drafting
Pr©cision drafting (#4604)
Hello, via cad has problems of precision. For example a line in 330 degrees is in reality 329, xxxxxx. is it always necessary to type 6 numbers after the comma "330,000000" to have degrs really 330? Shark, the same problems?
Thanks: 224 times Was thanked: 177 time(s) in 107 post(s)
Originally Posted by: appli Hello, via cad has problems of precision. For example a line in 330 degrees is in reality 329, xxxxxx. is it always necessary to type 6 numbers after the comma "330,000000" to have degrs really 330? Shark, the same problems?
I don't see that on Shark.
"330" is "330", or "-30" !
Hello. Did some Tests. Was able to have 1 Time your result under Viacad V7 Pro Build 967 on Windows XP, but never again, regardless of version and what i tried ... Which Version/OS you are on ? Maybe a round off/snap problem ? What Units do you use ? How many decimals ? Do you use Komma or Point (localization) ? How big is your snap radius ? Repeat what you have done and try to keep track of these settings. Maybe this thing can be tracked down ... Roland
Viacad V8, windows 7 64, and viacad 6 on mac intel. I have un old turbomac, only 3D, it's like viacad pro, with surface modeling.
2D Drafting
