Solid Modeling
Copying existing sketched lines into a new sketch (#1056)
                I'm trying to figure out how to transfer or copy an existing sketch on one face of a 3D object into an adjacent sketch on a new face in ViaCAD. Is such a thing available in ViaCAD?
                I believe the Americans use the expression 'bump'?!
                I'm not sure if I'm understanding the question. Copy and paste the curves then moved the new lines to the spot you want them. There is just one big 3d sketch in viacad and it just depends on what's selected.
                lebeau wrote:
yes and no, but mostly no. lol!
Have you used Solidworks at all? It makes a lot more sense if you are an ex-Solidworks user (like me).
In Solidworks while editing a sketch, and while in wireframe mode, it is possible to copy selected entities from one sketch to another. I thought that this would be possible in VC, considering that both are alike. But it seems you can't. Or at least I don't know how to. Copy and paste does not work, or at least it wouldn't for me.
Try it. Perhaps you know what to do?
:D
                if you create circle and extrude it you get a cylinder. The circle you selected for the extrude is the sketch of that cylinder. select the circle copy and paste you'll get another circle then extrude that. This same principle is the same for selecting multiple curves that make up a profile. In punch software you don't enter and exit sketches. You work always in a 3d sketch, each sketch is composed of the curves selected for each operation. In shark you can apply constraints to those sketches. (the profiles that make up each operation)
                Hi TTRW
                Hey Chuck :)
                Nope.
                Hmm perhaps not. Just hit another little snag- and that this tool only seems to work with curves (arcs) :(
Solid Modeling
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
