CNC_Kid
#1 Posted : Friday, March 7, 2014 6:40:57 PM(UTC)
CNC_Kid
using CTRL key and subtract solid should subtract solid and keep it? but when i move the object the subtraction shows until i let off the mouse. i see this in v8 too, so not sure if its me or a bug. windows version.
http://youtu.be/Nwz4PgAoMyw
if i reverse selections the sphere comes away with a subtraction.....
VCpro v11-1417
Win10Pro 32GB
Xeon E3-1270-v3 3.5GHz
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
zumer
#2 Posted : Friday, March 7, 2014 7:59:00 PM(UTC)
zumer
The parts are associated. If you move the subtrahend that you've elected to keep, the subtraction volume is moved as well, mating faces are updated. Select and edit|remove links breaks the association, move the subtrahend and the "bite" is static.
CNC_Kid
#3 Posted : Saturday, March 8, 2014 10:46:35 AM(UTC)
CNC_Kid
ah, i see that, thanks, i thought it was something. but honestly, i dont really get that functionality. seems logical that using CTRL would just do the subtraction w/o deleting the object and it be static. whats the use of making subtraction only when the subtracted object is touching the other one? isnt that about the same as two solids intersecting? is there a way to make the "remove links" part of the operation when doing CTRL select?
here's example, i have a 1" thick 20" dia disc, i place 1/2" dia spheres around the face of disc partially into the disc, say one every 15 degrees, and i want to make dimples by subtraction but i want to keep the spheres for another operation..... is there any setting to be changed that will do this during the CTRL subtraction or do i have to use remove links? removing links does other things which may not be desirable??
UserPostedImage
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
rockyroad_us
#4 Posted : Saturday, March 8, 2014 10:55:05 AM(UTC)
rockyroad_us
That's the point of the option key to keep the second part so that you can use the same sphere in another operation. Not only that but just in case you want to change the size of the sphere. If you change the size of the sphere, the bite automatically updates.
If you need another sphere, just use the drag and command (at least on Apple) and drag any arrow from the gripper or you can just duplicate the sphere with right click. You can duplicate as instance or with history in the same location.
cheers!
CNC_Kid
#5 Posted : Saturday, March 8, 2014 1:27:47 PM(UTC)
CNC_Kid
but if i move the solid the subtraction moves with the solid i am moving, that makes no sense. if i adjust size of the 2nd object and the subtraction changes accordingly (because its linked) , then thats fine. what i dont understand is, why does the subtraction area not stick? in my video you can see that once i move the 2nd solid the subtraction on the 1st goes away. that doesnt make sense to me. whats the point of doing the CTRL subtraction if the 2nd solid has to remain intersecting the 1st??
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
zumer
#6 Posted : Saturday, March 8, 2014 3:04:50 PM(UTC)
zumer
The subtraction itself is an editable feature in the history, you've moved the space it happened in (is "happening in"). If you want a dissociated subtrahend, either break the link or subtract a copy of the part, without opting to keep it. You could also use a copy for whatever afterwards and hide the parent, keeping the subtraction associated.
CNC_Kid
#7 Posted : Saturday, March 8, 2014 3:57:59 PM(UTC)
CNC_Kid
i didnt move the solid that had the subtraction done to it (the 1st solid), i moved the object used to make the subtraction (the 2nd solid).
ok, even with all the explanation of what VC is doing, whats the usefulness of making a subtraction using CTRL key?
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
zumer
#8 Posted : Saturday, March 8, 2014 5:24:15 PM(UTC)
zumer
One offhand example: subtracting one subtrahend from more than one minuend. Changes propagate both ways.
macnavi
#9 Posted : Tuesday, March 18, 2014 7:34:19 AM(UTC)
macnavi
Netherlands
It's really useful. I normally put the subtracted piece in a separate layer, which I then can make invisible after subtraction. Later you can change easily the size if necessary, so the cut out part will immediately change because they are always linked. You can also inspect the size and you can duplicate it to use elsewhere (or later on in your case). Really handy!
CNC_Kid
#10 Posted : Tuesday, March 18, 2014 8:55:20 PM(UTC)
CNC_Kid
the linking feature has usefulness, but maybe adding CTRL+ALT can do unlinked subtraction?
VCpro v11-1417
Win10Pro 32GB
Asrock Extreme 9ac
Samsung SSD RAID5
nvidia GTX760
Guest (5)
