ttrw
#1 Posted : Saturday, June 23, 2012 6:12:28 AM(UTC)
ttrw
Guys, how do I edit and save the MtoS templates, so for example it doesn't read all measuments in inches? Taylor them to my on specifications?
Many thanks.
Tom
#2 Posted : Sunday, June 24, 2012 12:28:00 PM(UTC)
Hi Tom
You can create a new file for mts and save it in the folder that stores model to sheet templates.
So you can build a metric file drag a border and title block in from the symbols Ungroup and modify as needed
Create empty single draw views and modify as required. Whatever settings for each view scale size etc
Save the file in the folder and it will show up in the mts drop down to select.
ttrw
#3 Posted : Sunday, June 24, 2012 1:39:11 PM(UTC)
ttrw
Thanks Jason.
The extension name too? Do I same as a vc3 file as normal, and then change the extension name back to vcp manually? I'll have a try.
Tom
