Thor
#1 Posted : Wednesday, July 18, 2012 10:30:50 AM(UTC)
Thor
Hi - So I have searched for this - and can't seem to figure it out, so I am asking for help.
I am trying to make a Moebius strip, very simple really, but not...
So, I take a strip, flat but with some thickness, I twist it 180 degrees down the center - so far, so good.
Now I want the ends to meet, so I bend it 360 on the side and my headache starts...
Also tried bending to a line, both a circle and an arc - no luck.
[ATTACH]4464[/ATTACH]
[ATTACH]4465[/ATTACH]
Any thoughts? I'm stuck here.
Ok, this is the best I have gotten - ends do not meet, the look is good - but closed would be better... :-)
[ATTACH]4466[/ATTACH]
moebius work Twist.vcp (40kb) downloaded 5 time(s).
moebius work 2.vcp (83kb) downloaded 5 time(s).
moebius work Twist and Bend.vcp (81kb) downloaded 5 time(s).
rockyroad_us
#2 Posted : Wednesday, July 18, 2012 3:22:55 PM(UTC)
rockyroad_us
You need the advanced feature bend along curve.
blowlamp
#3 Posted : Wednesday, July 18, 2012 4:28:46 PM(UTC)
blowlamp
Here's a video of a quick way to do one that should also work with more complicated paths.
http://screencast.com/t/kf3bj4V3Da0
Martin.
billbedford
#4 Posted : Thursday, July 19, 2012 2:22:51 AM(UTC)
billbedford
Even simpler would be to start with a circle and use a one rail sweep solid with a 360 deg twist.
blowlamp
#5 Posted : Thursday, July 19, 2012 3:35:25 AM(UTC)
blowlamp
Agreed, Bill.
I'm not sure why I made it so long-winded, I didn't even need to rotate the polygon about the Y axis for the purpose of the demo - must've been a mental block :)
Martin.
rockyroad_us
#6 Posted : Thursday, July 19, 2012 7:20:01 AM(UTC)
rockyroad_us
Good call bill.
I forgot about the twist on the one guide rail.
Thor
#7 Posted : Thursday, July 19, 2012 8:56:00 AM(UTC)
Thor
Martin, that is brilliant. And you got the degrees right, a 360 twist would not make it moebius...
Thanks, that is a completely different approach than mine, and far better.
Learning stuff.
gibbo_gt40
#8 Posted : Friday, July 20, 2012 9:03:38 AM(UTC)
gibbo_gt40
One sentence and I learnt so much, the single rail tool and the gripper.
twisted_hexagon.vc3 (37kb) downloaded 7 time(s).
