Surface Modeling
Clip plane cuts - color change? (#4006)
Hello,
when I use the "clip plane" view the "cutting area" of the solids always have the same plane gray and not the color of the solids.
I think a colored cutting area will be much more clearly, especially when you have few assembled parts:
Is there an option in the program to switch the "cut" color from gray to the same color as the solid has?
Thank you,
Harald
Originally Posted by: TeraVolt I think a colored cutting area will be much more clearly, especially when you have few assembled parts: Harald
I agree with Teravolt !
JL
indeed ! ... or, to an alternate colour like red in order to highlight the cut plane ?
Hello, have found out, that the color of the cutted area is not always grey, as I think first. The cutted area shows the color oft the infinite plane, used to clip. :eek: Be hopeful, that this bug is eliminated in the next building of ViaCad Pro,[COLOR="red"] Tim please! [/COLOR] I often have to create parts, where they stick each into another and the clip plane function would be very very helpful if it works as it should . Thank you, Harald
Originally Posted by: TeraVolt I often have to create parts, where they stick each into another and the clip plane function would be very very helpful if it works as it should .
I keep plugged to Teravolt!
Surface Modeling
