polygone
#1 Posted : Friday, April 18, 2014 12:19:35 AM(UTC)
polygone
The CutOut tool doesn't make a second cut on the same surface with an existing CutOut, no matter how small the diameter of the first cut is. In order to simulate a counterbore, you would need to use the CutOut tool on the first circle, then extrude the second circle, align the two top surfaces, and then make a Subtract Solid.
correction --- (It seems to only have this issue when the two diameters are concentric)
FX v8
polygone attached the following image(s):
CutOut Tool.jpg (158kb) downloaded 8 time(s).
billbedford
#2 Posted : Friday, April 18, 2014 2:52:10 AM(UTC)
billbedford
There is a counterbore tool....
polygone
#3 Posted : Friday, April 18, 2014 10:13:11 PM(UTC)
polygone
there sure is a tool for that, I've never notice it, Thanks...
