polygone
#1 Posted : Wednesday, March 26, 2014 3:13:29 PM(UTC)
polygone
Let say I wanted to draw a gear for a watch, or a dart set for a ant, How would a guy set this up using the "new using wizard"...? It appears - you can only shrink an object using the wizard and not enlarge it.
I guess I'm asking where the other end of the scale is, the 2:1, 4:1, 8:1 at set up time.
I see you can set the other end of the scale in "model to sheet," going form 3D to a Sheet, but "model to sheel" appears to do nothing in 2D drawing. I just created a simple drawing in 2D; top, side, and front views. slected it with the "Model to sheet" bonding box and nothing happens, there is not even a sigle line on the A sheet. I also created a drawing using the "new using wizard"...? method and used the "model to sheel" and again nothing happens.
Why does the option to "model to sheel" appear if it doesn't do anything?
I mostly do 3D to animaton, But now I need to draw something small and hand the drawings over to a machine shop, I would like the option of dwaring it in either 2 or 3 D.
What am I mising?
Thanks guys...
P
#2 Posted : Wednesday, March 26, 2014 3:38:39 PM(UTC)
Ignore the wizard would be my advice
