polygone
#1 Posted : Thursday, July 18, 2013 3:45:27 PM(UTC)
polygone
While trying to get my lines appropriately proportional for an A sheet patent drawing, I noticed what you see is not what you get. Meaning, lines on screen vs. printing. Check out the screen capture of a line weight sampler I made, on screen the 2 pixels looks thicker the .020 line, but if you print out the sampler you'll see these two are not even close.
I actually measured these line at 5X magnification to .001 of an inch, the bottom row lines position are relative to the thickness of the lines in the above rows.
P
Files saved to v5.5 Shark, ViaCAD v6
Line Weights.sfx (14kb) downloaded 7 time(s).
polygone attached the following image(s):
Tem
#2 Posted : Friday, July 19, 2013 2:20:34 AM(UTC)
Tem
Its sometimes better to just do what you've done to know what you will actually get on your prints than rely on the monitors representation.
#3 Posted : Friday, July 19, 2013 10:39:14 AM(UTC)
P
Hi P
Printing
Change all your lines to a set value not pixel,
if you print 1:1 scale the lines are the value they are set to lines .015" thick print .015"
if you print a drawing say 1/2 size 1:2 then a .010" thick line becomes .005" on the printed paper
Viewing on screen
there are three pen weight settings in the preferences
1. weights off lines stay a minimal thickness regardless of zoom level
2. display as printed - shows actual printed output
3. display view scaled - modifies as you zoom in and out on geometry.
