sah
#1 Posted : Monday, April 16, 2007 8:54:22 AM(UTC)
sah
Using EI Modeler you had an object export tessellation selection setting. Is there a setting like that in ViaCad to use before exporting as a fact file? Thanks
#2 Posted : Monday, April 16, 2007 9:45:14 AM(UTC)
You can convert the object to a mesh which provides a variety of tesselation settings. Use Edit:Change Object type to get access to normal & surface deviations, aspect ratio, and edge length parameters.
bmeissner
#3 Posted : Monday, April 16, 2007 10:53:14 AM(UTC)
bmeissner
Tim Olson wrote:
Use Edit:Change Object type ...
... or simply use the corresponding options within the export dialog?
Bernd
#4 Posted : Monday, April 16, 2007 1:45:06 PM(UTC)
Yes, the export to FACT command has the same mesh settings dialog box.
