                Using the Pyramid Diagonals tool, I select the lower left point of the pyramid and the lower right point to match a square drawn in that plane (400mm x 400mm).  Then a click for the height.  The pyramid drawn appears with a diameter of 400mm on the diagonal instead of the selected diagonal of the corners of the square (~565.685mm).  How do I make a pyramid that will fit on a base block where all the sides match?
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
