Is there a way to import/export to Microstation .dgn files?
Bad luck - I think nobody knows Can MicroStation save out a dxf / dwg ? I can imagine if you have an archive of drawings, this is a hassle Sorry - best I can do
If you have access to MicroStation you can export or import DXF and DWG files. The latest Version 7 can and V8 definitly. Look under the File pull down there should be a selection for import and/or export. Once the DXF?DWG is imported you can then save the file to a DGN format for Microstation.
if you have no access to Microstation you might want use the free
Teigha Viewer f. Win & OSX to convert DGNs from/to the standard for 2D data exchange = the DXF/DWG format.
hth
