tmay
#1 Posted : Thursday, September 18, 2008 2:58:18 PM(UTC)
tmay
I can get the cross section through a traditional split of a solid and extract of face geometry, but if there is an easier way or a tool specifically for that I would be interested to hear of it.
thanks,
tom
mikeschn
#2 Posted : Thursday, September 18, 2008 5:32:14 PM(UTC)
mikeschn
Yep, you can cut a section...
First you need to add an infinite plane where you want the section cut.
Then you can cut the section. See the pic below...
UserPostedImage
Mike...
tmay
#3 Posted : Thursday, September 18, 2008 6:07:41 PM(UTC)
tmay
UserPostedImage
Mike...
I tried that procedure and it works fine. I suppose I need to test more of the surface tools to see the behavior on a solid.
tom
